INTERMEDIATE STEERING SHAFT
dcozzi
4,576
Phoenix, AZ
no there is no modifications, you do need to check clearance between the lower joint and the frame.
I will need to know the year of the car and any changes made such as column or steering box.
Good call on the frame. It is close with those heavy duty ones. I cut a slit in the frame with a cutoff wheel, bashed it in with a 3lb sledge then welded the cut closed for clearance.
79T/Aman
NastyZ28 Sponsor
NastyZ28 Sponsor
2,629
Dickson TN.
yes i can see that.. borgeson way more, are yours collapsible steering shaft are the joints Vibration Damper
yes ours is collapsible, I was always a proponent of having some sort of dampening but after a couple years of I've come to the conclusion that not having the damper has not significant effect other than provide a more positive feel, HOWEVER! as stated on the web sit, they are sold as racing components for that reason, it is up to the consumer to determine if they want to use racing parts.
biker
5,057
Yes it is the same thing except we provide shafts already made to fit, no need to go on a hunt for all the parts, our shafts are plated and are more reasonably priced.
Hey man! I'd like to buy a shaft for my 81. Best to give you a call or go through website?
Dec 15, 2020
94
I called he said hes having supply issues like everyone else. So from Amazon I ordered a Borgeson telescopic shaft 450024 and 2 WMPHE ujoints 1 in DD to 1 in DD and
3/4 30 spline to 3/4 DD all together 155 bucks ordered yesterday receiving today
I just got to cut the shaft to length hope this helps biker dude
  • Like
Reactions: Zee
biker
5,057
Thanks man! That is a huge help. I will do the same, and keep you updated.
Canadian Barton
377
Alberta
Do you have part numbers for the ujoints, I am looking to do the same. Thanks in advance!
