need-for-speed
Is there a thread that tells how to get the intermediate shaft out? Mine is a ‘79.
2 bolts and a BFHIs there a thread that tells how to get the intermediate shaft out? Mine is a ‘79.
2 bolts and a BFH
Yes, the shaft maybe a bit subourn but it will loosen up. on the steering box side may help to finesse the rag joint with a pry bar or large screw driver.So after removing the two bolts, there’s enough telescoping action in the column to collapse it (enter BFH) to the point that it pulls off of the spines, and it comes out? Is that correct?
Much appreciated Bandit!Yes, the shaft maybe a bit subourn but it will loosen up. on the steering box side may help to finesse the rag joint with a pry bar or large screw driver.
I never needed to do that. Sounds like it might be an option once you get to removing the shaft.Much appreciated Bandit!
I read in one thread where the guy removed 2 steering gear bolts, and loosened the third to allow wiggle in that end. Do you think that would help get the shaft out?
thanks for the info. Now I gotta decide if I wanna replace the steering gear while I'm at it. I think I do.....time for more thread searches...I never needed to do that. Sounds like it might be an option once you get to removing the shaft.
