Is distributor restamped?
Discussion in 'Original Drivetrain Topic' started by Rosster, Oct 9, 2020.
  1. COPO
    20,873
    2,465
    I would not buy it if it looked like that.
    KingofThings likes this.
  2. flowjoe
    8,047
    45
    Feb 7, 2006
    SoCal
    The housing of the distributor in question has definitely been worked over - as already pointed out, it should have the machining marks visible. That would be enough for me to not do the deal as there will always be a giant question mark hanging over that distributor.
  3. Rosster
    Rosster Veteran Member Gold Member
    547
    262
    Mar 1, 2020
    Well, after looking it over, dimensions appear to be Machined identical size to the known Original 112168 distributor I pulled out of this car. It has the correct vacuum can as well as the 530ccw shaft. It does appear that them stamping impression is more pronounced at the beginning and end which I would think would Be Opposite if it was an attempted flat stamp. Also there are some marks from the tooling but pretty faint. Some remnants of yellow paint are on the base too. Here are the dimensions of both using my starrett outside micrometer. Give me your thoughts please especially regarding the diameters I found.
    1112168. 3.812” stamping area diameter
    3.798” cap mounting diameter
    1112019. 3.812” stamping area diameter
    3.796” cap mounting diameter.
    2ndGenCrazy likes this.
  4. 67johnny
    67johnny Veteran Member
    291
    18
    Apr 14, 2016
    vancouver
    Do we by chance know how many places were producing these distributors for GM in that era?
    Wondering if there were multiple factories that may have had slightly different manufacturing processes or fonts etc.?
  5. 70lt1z28
    4,302
    991
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Delco-Remy exclusively. Anderson Indiana I believe.
  6. COPO
    20,873
    2,465
    Mine is 3.816 on the widest edge.
  7. jbloake
    jbloake Veteran Member
    417
    104
    May 1, 2002
    Atlantic Canada
    Here is 3 more . I can’t say they are restamped, but it’s funny they all have the same date and quite different condition. 16CE4FC5-B8D8-425B-8983-E5A0FC3EC455.jpeg C184DA3D-9322-41D1-9A74-2555D9DDE51A.jpeg 4993209C-8C28-40EE-80D2-F4A41284A0AA.jpeg
  8. Rosster
    547
    262
    Mar 1, 2020
    I’m going to surmise that these were some one off run of parts then. There is zero evidence it was turned As it’s .004” variation In diameter and stampings were more than .002” deep. Either someone bought new unstamped items years ago For resale (unlikely as they had little value back then) or they made A small Batch run for some reason at the factory the following day (Possibly some rejects were found in the machining operation On day 1 so they had to adjust and Run additional parts the following day to cover those rejects. This one is in good shape otherwise so I’ll go ahead and rebuild it. Thanks to all here for your help and Comments . It’s invaluable!.
