Is there a better way than jacking up your car to work under it?
Discussion in 'Tips 'n' Tricks Topic' started by slayer021175666, Jan 13, 2021.
  1. John Wright
    15,298
    434
    Aug 9, 2002
    Rustburg, Va
    Maybe add a fan? Keeping the air moving bound to help with heavy fumes finding the low place to congregate. Adding a CO2 or carbon monoxide monitor might help with unknowingly working in heavy concentrations of carbon monoxide. Adding a rail at each side to keep a tire from accidentally slipping off the edge. Adding a top that can support a heavy load when not in use to keep someone from accidentally walking off into it. Adding some cave-in protection might be a good idea too.....there are lots of common sense things that can be done to make a pit safer. My grandpa had one we all used as kids to work under the car. I remember leaning out of the window trying to make sure the front tire was positioned okay while pulling in.
  2. BonzoHansen
    21,003
    1,934
    Jun 1, 2005
    Scott from Hamilton, NJ
    ^^cave-in protection might be a good idea? lol
    I've used a pit. No thanks. I guess they are good for some fluid changes.
  3. Bentley
    Bentley Veteran Member
    141
    69
    Aug 14, 2020
    Local chevy dealer here (Stingray in Plant City, FL ) has a pit for the "complimentary" oil changes they offer.. It has to be about 4 car length's long... It has some metal panels that are not quite flush with the top, that slide out of the way when working in one area of the pit..... I think they would support a car.... Not a bad idea " I was thinking" when I looked at it the other day...
    WILLIAM FLYNN likes this.
  4. 2ndOwner78
    2ndOwner78 Veteran Member
    131
    82
    Nov 6, 2014
    Minneapolis, MN
    We had a grease pit growing up on the farm. But it was in the dedicated shop, not connected to a house. It was put in during the initial construction, no added later. We kept it covered when not in use and it was very useful.
    The one drawback was in the spring thaw when a good foot of water would seep in, that only happened when I HAD to use it for something though. :)
    Farmers probably do a lot of "stupid" things in some peoples opinion but for the most part they have common sense and build in basic safety procedures. They are in more dangerous situations than most people deal with on the daily so it is top of mind. It becomes second nature to know how to behave around PTO shafts, dangerous chemicals with fumes that kill, working in and on massive machinery and of course where you should and shouldn't place your head around large animals.... :)
    Bentley likes this.
  5. BonzoHansen
    21,003
    1,934
    Jun 1, 2005
    Why did you guys make them rectangles and not squares at 16x16?
  6. Bandit723
    Bandit723 Veteran Member
    3,826
    741
    Oct 1, 2016
    Waupaca WI
    I came up with this size to fit the tire. I am sure 16X16 would have worked out just as well.
  7. WILLIAM FLYNN
    WILLIAM FLYNN Member
    35
    Aug 29, 2020
    2015 i had to lay 2 2x12s down drive on and than jack it up pia
  8. Robinator
    Robinator New Member
    14
    Jul 26, 2021
    Norrtälje, Sweden
    Someone who tried this type of ramp?
  9. rocket dawg
    rocket dawg Veteran Member
    522
    71
    May 5, 2015
    Grand Rapids Mi
    Had the front tires on ramps. Axle on jack stands. Okay, time to lower car. Placed jack under rear differential and up it goes. Pulled both stands out from under axle tube and then the car starts rolling backwards off the ramps. Car pushing the jack while I'm behind/under it on my knee's. Glad it wasn't close to the garage door or it could have gotten ugly. Lesson here? Block the front tires on the ramps if you decide to do this.
  10. Robinator
    14
    Jul 26, 2021
    Norrtälje, Sweden
    Ok, then i will look for another option. These looked good cause of the built in jack in the ramp.
    But i was a littlebit sceptical. Thanks!
