Blackbirdtom
- Nov 23, 2020
- 10
I saw that someone here lift his 2nd gen camaro by the pinch weld
Mine is a 1970 one
I have a 2 posts lift, usually I lift my camaro by the front subframe and the rear frame near the springs leaf pockets
But now I need to lift it by the pinch weld because I need to remove my rear leaf springs and my bolted subframe connectors (so I can't use the rear jacking points on the subframe)
I want to use the pinch weld for the rear with pinch weld blocks (and frame for the front) but I'm not sure where to put the lift on the pinch weld
Do you have photos of where you put the lift on the rear pinch weld ?
I m afraid of using the pinch weld because I have always used the frame.
Is it really safe ?
Mine is a 1970 one
Is it really safe ?
