Is there a better way than jacking up your car to work under it?
Discussion in 'Tips 'n' Tricks Topic' started by slayer021175666, Jan 13, 2021.
  1. slayer021175666
    slayer021175666 Veteran Member
    1,320
    80
    Feb 29, 2016
    Idaho
    Do you guys think it would be okay to pick it up by the pinch welds as long as you had those slotted blocks? Another thing is, what about just making some out of pieces of 4 x 4 with a slot cut into them?
  2. The Champ
    The Champ Veteran Member
    5,321
    992
    Sep 14, 2000
    MN
    I didn't stay at a Holiday Inn Express last night, and don't claim to be an engineer...
    The problem I see with that idea is that you would need to lift both sides at the same time to safely accomplish that. If you were only raising one side at a time, the pinch weld on that side would have a huge amount of pressure applied at an angle which would cause the pinch weld to distort. Then when you go to the other side, the slot would not line up allowing the pinch weld to drip into that slot.
    If you tried to use two floor jacks and with two people attempting to lift both sides at the same time, the positioning of the floor jacks would be critical. If you aren't both at the precise center of weight distribution, the car would start to tilt to either the front or the rear (think of a teeter-totter with two different sized kids). It might work with 4 floor jacks and 4 people...
    The quick jack works with the pinch weld blocks because the car remains level as it's lifted, just like a convention 2 or 4 post lift.
  3. MP81
    MP81 Veteran Member
    444
    32
    Oct 10, 2016
    Washington Township, MI
    I think you might be overthinking it a little - remember, most newer vehicles use the pinch welds as jack points - they're pretty strong, provided the sill isn't rusted out, or the flange isn't already bent (from someone jacking up on it without using some kind of slotted apparatus.
    That all said, as a former BIW engineer, I would expect we're probably missing at least one metal thickness in our pinch flanges compared to vehicles these days. Usually the pinch flange - at least near the designated jacking points - is a 3T situation (three metal thicknesses), and one of those nowadays is going to be some form of high-strength steel.
    I haven't taken a look at the pinch flanges on my '81 to see how many metal thicknesses we're talking about there - but up until now, I've always jacked the front up via the subframe.
  4. SPG
    SPG Bumblebee Builder
    949
    303
    Sep 1, 2018
    Sacramento
    The pinch welds were bent to hell on my car by some other moron jacking it up that way....wouldn't recommend it
  5. MP81
    MP81 Veteran Member
    444
    32
    Oct 10, 2016
    Probably because they didn't use something slotted to keep it from bending. They're strong when you jack up vertically on the edge of the pinch flange - once they're bent/crumpled, all that strength goes away.
  6. slayer021175666
    1,320
    80
    Feb 29, 2016
    Idaho
    I still wonder if just a piece of 4x4 with a slot cut in it would do. Those pinch weld blocks from Quickjack are 80 frickin bucks! Seems quite steep for 4 blocks of plastic or rubber or whatever they are.
  7. BonzoHansen
    20,651
    1,746
    Jun 1, 2005
    Scott from Hamilton, NJ
    wood splits, i would not. I will be buying the proper blocks. although i do not think will be picking the camaros up at the pinch welds.
    Knuckle Dragger likes this.
  8. The Champ
    5,321
    992
    Sep 14, 2000
    MN
    They are very HD urethane rubber. Very solid. They work. They will last a lifetime.
  9. CorkyE
    11,217
    836
  10. BonzoHansen
    20,651
    1,746
    Jun 1, 2005
    if you only want the 5000 version that s a nice buy. with hangers and the PW blocks.
