Is there a better way than jacking up your car to work under it?
Discussion in 'Tips 'n' Tricks Topic' started by slayer021175666, Jan 13, 2021.
  1. Bills69
    Bills69 Veteran Member
    295
    34
    May 28, 2018
    check for lift point measurements , might be long enough for some cars and not others . You may want another model to accommodate your other vehicles as well
    the 5000 works for camaros but not my every day car
  2. CorkyE
    11,393
    915
    My daily driver is a Silverado. Driving it up on ramps is quick and gives plenty room to service it.
  3. autobahn
    autobahn Member
    53
    11
    Jun 8, 2005
    55963
    I use these and they work very well, My concern is the way they are being used in the 1st pik they on the pinch weld BUT at one edge which makes it unstable ,I work in the pipe fitting business for 45 years and I WOULD NOT go under that car the way they are placed
  4. Bills69
    295
    34
    May 28, 2018
    just a heads up . that is a good price
    I have the original 5000 which is a little smaller and can not use the extenders you can get now
  5. The Champ
    The Champ Veteran Member
    5,471
    1,100
    Sep 14, 2000
    MN
  6. CorkyE
    11,393
    915
    I went ahead and ordered it from Costco, hopefully it works as it should. Have you tried lifting your Camaro with the Quickjacks turned sideways as show in the video? If so, where did you place them?
  7. The Champ
    5,471
    1,100
    Sep 14, 2000
    MN
    Corky
    I have not and don't think I would want/need to. If I did, I'd probably use the same lift points as the normal way.
    Remember if you do that, the car will move east/west instead of north/south.
    Bills69 likes this.
  8. sandlapper
    sandlapper Veteran Member
    844
    318
    Oct 9, 2020
    SE CSA
    as in post #3
    dig a pit fka "grease pit" ... shovel, bucket, elbow grease, determination & time.
  9. TTR230
    TTR230 Veteran Member
    520
    263
    Aug 1, 2020
    Burlington, Ontario
    I think a grease pit is a surprisingly underused idea. Much easier than building up in limited height buildings. Probably not legal in some areas, but "why invite the government into your life?" is my personal motto.
    WILLIAM FLYNN likes this.
  10. 1978 Z/28
    1978 Z/28 Veteran Member Gold Member
    368
    205
    Jul 17, 2017
    New Brunswick
    Grease pits are a bad thing, cars drive into them, people fall into them and they can be come a dead air space for heavy fumes to collect
