Is this for real? '70 12 bolt
ronzz572
2,479
imperial pa
Unfortunately yes on the price. One year only specific 70 z28 parts are getting pricey. Especially when the condition of them are good.
badazz81z28
22,132
Alabama
I don't think so.....There's a big demand for the person who needs it....which is just as rare as the rear-end itself. Years ago, if you wanted a 12 bolt, this was your direct bolt in option. These days we have direct fit 9" and 12 bolts that are way stronger than these OE units. I would never spend that kind of money for a bare housing unless it was for a 100% correct build.
ronzz572
2,479
imperial pa
I editing this since I didn't write my actual intended reply correctly in my first post.. Right now the the 70 z28 camaro is a very popular car in the restoration world. Someone restoring the right car will most likely pay that price to get that nice housing. If I needed for one of my cars I sure would consider it.
badazz81z28
22,132
Alabama
^^ agree, any part that is correct for a Z28 or L78 that is specific to these models are going to be expensive. The buying audience is just small because the production of these models is small. Even more when it’s a date coded item.
Rosster
943
I’ve seen them sell for $2500 complete so not far off the mark. As said above, you can buy a moser 12 bolt for that so for a non restoration it wouldn’t make sense to not buy new.
badazz81z28
22,132
Alabama
Depends I guess...are you a die hard restorer that wants the correct GM gear and posi too? Axles? Brakes? Hunting these parts down to install in this housing can nickel and dime you. With all new aftermarket parts, with labor youll have over $2500 total invested in it. When I see bare anything....I always ask why was it taken apart?
Rosster
943
One reason I'm asking is I have been tripping over my original 12 Bolt out of my '70 RS!
I wonder if it's the same as the Z28 12 bolt?
Well, RS was a trim option and only SS and z28s had the 12 bolt. Likely upgraded from a wrecked one back in the day.
Rosster
943
I’m an amateur restorer but it’s unlikely someone will pull the axle cover to verify eaton posi date codes and GM gear sets. As you said, I’d be more concerned as to why it’s sitting stripped apart? Maybe housing was bent in a crash? Who knows?
