Is this for real? '70 12 bolt
badazz81z28
22,129
Alabama
I’m an amateur restorer but it’s unlikely someone will pull the axle cover to verify eaton posi date codes and GM gear sets
agree, same could be said about the casting numbers on the housing as well. It would have to be a meticulous build to have that standard. If the housing dates are that important, so will the guts. Look at Ron’s build, he is looking for date coded ball joints and rotors.
Gary S
24,584
Yep, you are correct!
I suppose I could check the # on it...
I've owned the car since 1980 or so and knew the second owner ....
Check the code on it. If it is a 3.73, it would be from a Z28. If it is a 4.10, it could be from a Z28 or a L78. If it is a 3.55, it is from a L78. If it is a 3.31, it is from a SS396/L34 or from a SS350. If it is a 3.07, it is from a SS350.
But, this axle was also used by Pontiac on the Trans Am and the Formula so it could be from one of them instead of a Camaro.
hwprouty
40
Granite Falls, Washington
I'll check it out, it had 3.73's as I recall.
With the 4 speed it didn't feel like 3.31!
Rosster
941
For camaros, 3.73 will have COZ stamped on it, 4:10s are COO. Not sure whether pontiacs used the same codes or not (unlikely)
