Is This Really A Z28???
Discussion in '1978 - 1981 Specific' started by JCSilver80, Aug 18, 2014.
  1. thomer
    thomer Veteran Member
    118
    Sep 13, 2009
    ohio
    I didnt realize that at all. Luckily for me mine was easy I found 2 build sheets so I knew it was a z regardless. However I just went and checked that data to my tag and it is correct. Good info to know. Thanks
  2. cws455
    cws455 Veteran Member
    288
    Sep 19, 2009
    La Porte, IN
    That is not true. 80 Z28's are the easiest to confirm via the vin. They were the only camaro's that came with the 350(5.7L) in 1980. So any 1980 camaro that has a vin that starts 1P87LAL is a Z28 built at the Van Nuys plant! If it has a vin that starts 1P87LAN then it is a Z28 that was built at the Norwood plant! Pretty simple. The Norwood trim tag will say Z28 on it. The Van Nuys trim tag will have just have 8.
  3. JCSilver80
    JCSilver80 Veteran Member
    672
    Sep 12, 2011
    Mobile, AL.
    Thanks for all the info fellas, I'm heading over this afternoon to take a look.
  4. FatnLow
    1,954
    Mar 12, 2003
    Montgomery, AL US
    If it has suspect rivets on trim tags I'd be leary.
  5. flowjoe
    8,047
    45
    Feb 7, 2006
    SoCal
    I was fairly certain that California sold Z/28's received the 165HP 305 CID engine. The upshot being that the fifth VIN digit would not be an "L".
  6. c120cut
    c120cut Member
    73
    Dec 22, 2005
    los angles ca.
    Yes 80 Z sold in California got computer controled 305
  7. 1981blackZ28
    1981blackZ28 Veteran Member
    157
    Oct 2, 2010
    Knoxville, TN
    So did you go look? Inquiring minds want to know....
  8. david.rosol
    david.rosol Veteran Member
    1,140
    16
    Jul 2, 2009
    Southern Maryland
    If the VIN/Trim plate were swapped with a known "good - titled" 78 VIN tag and & trim plate, the title will come back good, unbeknownst it may actually be a stolen 80 that had the VIN tag and trim plate replaced with one from a 78. That's how crooks pass off stolen cars now days. That's why I recommend looking at the hidden VINs.
  9. flowjoe
    8,047
    45
    Feb 7, 2006
    SoCal
    I think there is only one hidden VIN on 2nd gen's - under the heater box. Difficult to look at unless the car is in pieces.
    Earlier cars have a date stamped on the subframe rail under the driver's door. If later cars have this too then that would be another place to gather evidence (i.e. if the frame is dated for '78 then it would argue for a '78 - given the title - with '80 parts tacked on. If the frame reads '80 then all the illegal scenarios laid out above start to look more likely).
    this may be helpful:
    http://www.nastyz28.com/forum/showthread.php?t=115589
  10. 80NoiceBerlinet
    80NoiceBerlinet Member
    81
    Aug 21, 2014
    Princeton New Jersey
    there are a few things that are throwing me a red flag. among what the others have said there does not appear to be any of the z28 body decals on the front bumper ground effects, the fender, or the doors. there also appears to be a non-matched red induction piece on the hood. the interior looks to be modified and im thinking that they built the car from a different model camaro to look like an 80-81 z28 with the front end, and tail lights, and steering wheel. definitely need to closely look at the title, the trim tag and the vin plate. the vin plate and trim tag should be held in with rivets. look closely to see if they look new or if they have been replaced/painted
