Is this stock...door jam floor pan
Discussion in '1978 - 1981 Specific' started by JD Z, Jun 30, 2019.
  1. JD Z
    JD Z Veteran Member
    246
    17
    Aug 18, 2017
    Shawnee Kansas - Kansas City MO area
    D39C09CD-30A7-4896-9E03-AF5C1A73FE5F.jpeg I took the door jams off this weekend. I’m wondering what this tin screwed in is about. Was that stock or does it indicate floor pan work? Picture attached.
    Thanks!
    ggtsvnv likes this.
  2. Gary S
    24,069
    1,588
    I believe it is factory. If you remove the panel, you should see your wiring trough under there.
    JD Z likes this.
  3. jamieg285
    jamieg285 Veteran Member
    1,332
    20
    Jul 15, 2004
    Luton, England
    That doesn't look like the ones I have, so maybe just some homemade replacements?
  4. Glava
    Glava Veteran Member Lifetime Gold Member
    422
    36
    Mar 23, 1999
    Central NY
    Like Gary said, it is factory and to protect wiring that runs under it. I'm 99% sure that is exactly what the original looks like in my 79. Let me know if you need me to look.
    JD Z likes this.
  5. COPO
    21,095
    2,616
    My 80 Z28 that I ordered new was the same.
    JD Z likes this.
  6. Jonesy
    Jonesy Veteran Member
    533
    52
    Jun 7, 2008
    Minnesota
    That is factory stock. It does cover wiring and also helps finish off where the carpet and sill plate meet. Gives the carpet a rounder contour going up from the seat to the sill.
    JD Z likes this.
