It’s broke
Discussion in 'Transmission & Driveline Topics' started by 71Z28RS, Sep 9, 2020.
  1. 71Z28RS
    71Z28RS Veteran Member Lifetime Gold Member
    313
    25
    Jul 19, 2014
    Toronto
    FC949E01-1B11-4B47-A36C-6E4CE971FFCD.jpeg 0E97F189-7A2E-4418-8F75-791CEDDF2697.jpeg Apparently it is called a crossshaft
    I have no more clutch , pedal
    Will not return ...
    called gm , they gave me a discontinued part number # 3841490
    where can I find one in Canada ?
  2. flht99b
    flht99b Veteran Member
    836
    274
    Nov 28, 2014
    Knoxville, TN
    Looks to me the clutch fork has worn to the point that the adjustment pushrod has gone through it. If I'm seeing the pictures correctly, the clutch fork should be available from many places. The adjustment pushrod can be easily found too. Firms like NPD, Classic Industries, Camaro Central just to name a few should have what you need. Down side is transmission will need to come out. If the cross shaft is broken which I can't tell from the pictures, the same companies probably have what you need.
    Zstar likes this.
  3. Dave Nelson
    Dave Nelson Veteran Member
    5,260
    4,447
    Dec 19, 2003
    Vineland N.J USA
    Is that the stock return spring? Looks way too heavy of a spring compared to a stock one, that might have played into the issue of the rod wearing thru the clutch fork.
    Smokey15 likes this.
  4. 1978 Z/28
    1978 Z/28 Veteran Member Gold Member
    337
    170
    Jul 17, 2017
    New Brunswick
    Zstar likes this.
  5. Twisted_Metal
    29,659
    2,510
    Yup, It looks broke to me. :(
    Sorry, I'm no help on parts I just thought I would high-light the image so people know what you are talking about.
    (It took me a minute to see it.)
    Good Luck!
    Dave Nelson likes this.
  6. Zstar
    Zstar Veteran Member
    2,529
    845
    Mar 23, 2014
    Ocala, Florida
    ^^^^What they said.
  7. Twisted_Metal
    29,659
    2,510
    This part is worn through too. :(
  8. COPO
    20,871
    2,465
    There’s nothing a mig can’t fill. ^
    I had to add metal to the hole where the adjustment rod goes in.
  9. Dave Nelson
    5,260
    4,447
    Dec 19, 2003
    Vineland N.J USA
    I still think that is not the stock return spring, looks like a drum brake return spring, this could have contributed to both of the failures causing too much tension on the parts.
    xten, Budz and Smokey15 like this.
  10. Rosster
    Rosster Veteran Member Gold Member
    547
    262
    Mar 1, 2020
    This^^^^^^^
