450bench
On the 9 to 1 aluminum oval port headed 454 with the smallest thumpr cam, streetmaster single plane and 870 vac.sec. Holley, MSD pro billet and 6A box, the car just ran like garbage with my vacuum advance. Sputtered and fell on its face. Without the advance hooked up it ran fine.
After a buddy told me to jet the carb way up, I resisted for months. But I wanted to run the advance so I figured I’d try it so I jetted it up and put in a higher power valve. Monster difference and runs great. Vacuum advance also helps a ton obviously cruising around.
Is it the hotter spark requiring more fuel?
Went to 80s with a 9.5 PV and 90s with no power valve.
Plugs are perfect.
Plugs are perfect.
