JohnL71RS’s Project restart…..
Discussion in 'Project Progress' started by JohnL71RS, Nov 11, 2010.
  1. giggity
    giggity Veteran Member
    1,621
    411
    Mar 18, 2013
    Pearland, texas
    not sure if this helps...not a rally sport
  2. JohnL71RS
    JohnL71RS Veteran Member
    1,688
    66
    Apr 12, 2010
    Marrero, LA
    the glare is kind of bad. but it looks like there is two pieces. one ss piece for the weatherstripping and another behind it wrapping the quarter.
    thanks,
  3. JohnL71RS
    1,688
    66
    Apr 12, 2010
    Marrero, LA
    another issue. what holds the cable inside the door for the side mirror cable??
  4. giggity
    1,621
    411
    Mar 18, 2013
    Pearland, texas
    I think the door panel holds it.
  5. JohnL71RS
    1,688
    66
    Apr 12, 2010
    Marrero, LA
    i think there is a clip in the inside of the door frame that keeps the cable from interfering with the window. Mine keeps getting caught be the window when it goes down.
  6. xten
    xten Veteran Member
    4,435
    3,469
    Sep 24, 2014
    Pittsburgh, Pa.
    The cable has to go forward before it gets to the window. Goes toward the front of the door. Should be clips or brackets for the cable to slip into. If they're not there you can zip tie them to the support in there. The control goes through the bezel on the door panel before it's screwed onto the door panel and there's a "C" clip that holds the control to the bezel.
  7. mrfleet12
    mrfleet12 Veteran Member
    982
    645
    Aug 8, 2014
    West of Chicago IL
    I fed mine forward of the door glass then tucked it behind the inner brace, kinds of the loop if you will of the cable. Seems to work fine.
    There should be a little clip but mine is missing
  8. giggity
    1,621
    411
    Mar 18, 2013
    Pearland, texas
    because I was curious...I looked at my inner door. This is the clip that appears to hold the cable
  9. xten
    xten Veteran Member
    4,435
    3,469
    Sep 24, 2014
    Pittsburgh, Pa.
    Yep, that's it. If it isn't there you can zip tie it to the inner structure. Then it goes forward around the front window channel.
    mrfleet12 likes this.
  10. JohnL71RS
    1,688
    66
    Apr 12, 2010
    Marrero, LA
    i am looking to see if anyone has put an electric rack and pinion steering in their car. i have the regular manual one and it is hard to steer. hoping to find a rack that will fit from the junkyard. i see new ones, but the prices are way out there. thanks,
