Just pulled trigger on FiTech
Discussion in 'High Tech Retrofits' started by 408maro, Mar 6, 2016.
  1. 408maro
    408maro Veteran Member
    1,618
    Nov 27, 2008
    San jose,CA
    I do believe if I run its timing control option I can adjust more. I will have to see if I can adjust those.
    It don't smell as if it's rich it smells like straight fuel as if it's leaking but can not tell anywhere that it is.
  2. JWZ28
    JWZ28 Veteran Member
    1,239
    Feb 27, 2011
    Alabama
    My car runs so much better now that timing control is enabled so I don't think that you would regret that at all. You might find that with it enabled the fuel injection wants a faster timing curve.
  3. Itsadryheat79
    Itsadryheat79 Veteran Member Lifetime Gold Member
    321
    Aug 4, 2009
    Chandler, Arizona
    What distributor are you using?
    I'm trying to pick one now for a project and from the FiTech docs (Figure 12) this is an important consideration for the timing control. I'm going to use a MSD 6A box and looking at the MSD-8361 dist but it's expensive and probably overkill.
    When I inquired to FiTech sales tech line looking for a recommendation.
    Question:
    "Do you have to use a old school breaker-point ignition system or is there something better?"
    Answer:
    To run timing control you must have a locked out 2-wire magnetic pickup coil. You can use timing control with just a coil or a CDI box. To use the CDI box the EFI system triggers the coil via the points trigger wire of the CDI.
  4. JWZ28
    1,239
    Feb 27, 2011
    Alabama
    The MSD Atomic system required me to run the MSD Pro Billet 85551
    http://www.summitracing.com/parts/msd-85551
    It had to be locked out (which you can do as a feature with this model) and a phasable rotor. I also had to use an ignition box.
    This is the how-to for the Atomic EFI.
    https://www.youtube.com/watch?v=c1aiR0nw3Tk
  5. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    I have the same distributor. I was thinking of running the fitech timing control and may eventually and also will have to lock out the distributor to do so.
    Here is a video I did today. Not so happy with quality though. I'm sorry
    https://youtu.be/5JBr7ggOqn8
  6. JWZ28
    1,239
    Feb 27, 2011
    Alabama
    What was going on when the rpms dropped out?
  7. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    I had opened the cutouts and them closed.
    Here is another video I did on my go pro. I may redo the first one with my gopro.
    https://youtu.be/eAGFekAORLU
  8. JWZ28
    1,239
    Feb 27, 2011
    Alabama
    The sucking noise is definitely the IAC. If you have an auto trans and can adjust the throttle blades, I'd adjust it so that the IAC reading is between 5-15 when the engine is at operating temp (Between 10-20 for manual). This was the recommendation with my system and I've found that throttle blade adjustment really affects how well it idles and runs.
  9. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    Thank you. I will try that. Mine is a manual so I'll put it to about 10-20 when warm as you mentioned and see how it goes
  10. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    Buddy invited me to a dyno day his car Club had and she did 323hp with 360tq. Not to bad but I know she can do more
