Keep or scrap?
Discussion in 'The BS Topic' started by fatkid_racing, Sep 6, 2017.
  1. fatkid_racing
    fatkid_racing Veteran Member Lifetime Gold Member
    1,049
    90
    Sep 21, 2005
    Saginaw Texas
    I've been a hoarder of BBC stuff for a good while, which brings me to the question in the title. There's a 70/71 402 chevelle/monte carlo suffix partial short block that's been here forever would make a nice builder, steel crank, and dimple rods. Nobody wants it because it's an 854 casting 402 block not some coveted 396 casting, nobody wants the crank because it's turned .020 even though it's all very useable.
    Should I just throw it on the scrap pile or content to hoard it?
    Also on the pile is a set of 69 427 corvette exhaust manifolds. Keep or scrap?
    And a 71/72 402 287 casting Camaro intake manifold. Keep or scrap?
  2. 70lt1z28
    4,094
    925
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Don't know your space limitations, but anything that can be tracked to a Corvette (especially Corvette only) I would keep. The Camaro intake I would also keep as it doesn't take up too much room. The block and crank I would send to the great beyond. Run of the mill big block stuff I think is lessening in value due to the LS motor craze.
    Zstar and Buickfunnycar like this.
  3. 71 rs BBC
    71 rs BBC Veteran Member
    477
    65
    Nov 28, 2016
    Indy
    Everything goes in cycles. Pro street, pro tour, factor correct restorations. If it doesn't eat any hay I'd hang on. M2c
  4. RS1979
    4,005
    936
    Jun 18, 2013
    Memphis, TN
    Keep it. As soon as you scrap it, someone will want it.
    Zstar likes this.
  5. jimrr
    jimrr Veteran Member
    1,334
    307
    Jun 12, 2016
    sarasota
    Keep.
  6. Dave Nelson
    Dave Nelson Veteran Member
    5,071
    3,974
    Dec 19, 2003
    Vineland N.J USA
    Keep it, but the intake will bring between $150-$250 on Ebay.
  7. Zstar
    Zstar Veteran Member
    2,260
    694
    Mar 23, 2014
    Ocala, Florida
    The intake and exhaust manifolds I would keep. If you have had the 402 more than 6 months with no interest, it's time to go.
  8. budro6968
    budro6968 Veteran Member
    3,818
    716
    Apr 2, 2016
    Jax Florida
    EBay is the way to go. If no one hits on it then maybe scrap. Me I have too much stuff too. I guess when I die someone will have a field day.
  9. 71 rs BBC
    477
    65
    Nov 28, 2016
    Indy
    I have a 67 396 that my brother gave to me when I was 12. (1&2 bearings spun) It's on a cut off shopping cart base for almost 40 years. I still get offers for it. lol usually from someone doing a chevelle ( date code) One day somebody will want a date code BBC
  10. CamaroDoc
    CamaroDoc Veteran Member
    2,208
    246
    Sep 13, 2003
    Skiatook, Okla. 74070
    I'd say hang on to it. I've seen cranks turned .060 under that worked just fine...
