Key stuck in passenger door
Ben Plunkett
16
Hey all, first post here. I just bought a 79 Camaro and went to unlock the passenger side door. The key turned and is now stuck in the unlock position however the door did not unlock. The door won't unlock from the inside either and won't open at all this problem? I've tried wiggling the key and using wd-40 but no success.
Any advice would be greatly appreciated!
Itsadryheat79
322
Chandler, Arizona
Have you tried a slim jim tool?
Tool is used to lift or push on the bar inside the door to unlock it.
There are plenty of videos on YouTube showing how to do this - or call your AAA or a locksmith.
TTR230
619
Burlington, Ontario
Yes, I updated the post linked above with the solution. It's an easy fix. Pm me if you have any questions. before anything else, you'll need to get AAA to open the door. They will have to use a slimjim, none of their other tricks will likely work in this situation. Once you're unlocked, the door is absurdly easy to work on. The lock cylinder is held in with a horseshoe clip. You can hey to it with a long screwdriver from the too with the window down. Anything after that is way easier with the inner door panel off. That is also super easy.
Ben Plunkett
16
I haven't tried that but I will get one tomorrow and try it. Any ideas for getting the key out of the lock? I'm not sure if it's seized but nothing I tried could get it out.
Ben Plunkett
16
Perfect thank you, I'll give it a go and I'll pm you if I have any questions!
