Key won't turn
Discussion in 'Troubleshooting & Diagnosis' started by marauder64ky, May 29, 2009.
  1. marauder64ky
    marauder64ky Veteran Member
    163
    Jan 21, 2005
    Falmouth, KY USA
    Any ideas what would make the ignition not turn? Parked an old '72 about 2 years ago. Worked fine then. Jiggled the key. Turned the wheel a little. Jiggled the shifter. Nothing. And yes, I have the right key. Acts like it wants to turn but something is holding it back. Any help appreciated.
  2. marauder64ky
    163
    Jan 21, 2005
    Falmouth, KY USA
    It feels like it is ok at the key end. What could be hanging up on the rod or at the other end of the rod? Do I need to pull the wheel?
  3. lockguy
    lockguy New Member
    Oct 24, 2008
    sooke b.c.
    the only way your going to find out is to pull the wheel and remove the ignition, then you can test it in your hand. It may be the side bar in the ignition lock jambed, or it is farther down the colloum.
  4. Dukes72
    Dukes72 Veteran Member
    440
    Mar 14, 2008
    Central IA
    You didn't specifically mention if you tried turning the collar on your steering column at same time as working your shifter into Park. If you didn't try that, give it a shot.
  5. Mikey18
    Mikey18 Veteran Member
    325
    Dec 31, 2000
    Soldotna, Alaska
    That was the problem on my 81. Left it overnight at the mall, just to figgure out a little twist was all I needed.
  6. GoldenOne7710
    5,583
    854
    Jun 23, 2004
    Athens, GA
    Are the front wheels turned at all? Is it possible when you last parked the car that the steering wheel was turned ever so slightly and it locked with pressure on the column?
