Bandit723
Dude that is so Gear....Nice Job
I had a similar situation with my 72 C10, (they bent the header unloading off the flatbed) I wrapped a strap around the collector and pulled it back into place with the 12k pound winch on my truck (a little bit at a time). Do you know anyone with a winch. This could also be done on a frame machine.Camaro said it wants more attention,lol.
I had moved that header over,turns out it went right back to digging into the LCA boss midway thru the drive.
It's rubbing on the collector bracket that encircles the collector socket,thinner part.
So today Im going to see if there's enough room for me to remove the header with the downpipe attached in my garage,on my cribs.
If there is,Im welding my ball and socket connection.I don't see a way to save that ring with the amount of material I'd have to remove.
And that 16 guage header is too beefy to bend.
That's this afternoons bout,hopefully.
Colder here today than I thought it would be,but I glued down the intake,put the temp sensor in the intake since the new heads dont have a port for it.
Also put my blue vcs on.Ill put tge distributor in and drain tbe oil,rehook up the sniper and wires in the next couple days.
