Leaf shackle bolt removal
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Allison Winn, Feb 15, 2021.
  1. Allison Winn
    Allison Winn Member
    78
    9
    Jan 10, 2021
    No not stuck. These were SPI epoxied individually then assembled a month later. You can see through the spaces between each
  2. Budz
    3,254
    298
    Mar 17, 2002
    Ashburn, Va USA
    After re-installing, but BEFORE tightening any of the bolts, you need to lower the car onto the ground and possibly add weight in the trunk to make sure the full weight of the car is on the springs before tightening the bolts to avoid the dreaded 'ass in the air' look.
    T/A Tom likes this.
  3. meanv8
    meanv8 1980 Z/28
    58
    May 29, 2011
    Middle TN
    Mine were original and rusted as well. I had to cut mine with Sawzall. Cut off wheel may work also.
  4. Allison Winn
    Allison Winn Member
    78
    9
    Jan 10, 2021
    Thanks all - I am having them de arched
    T/A Tom likes this.
  5. T/A Tom
    T/A Tom Member
    37
    20
    Apr 29, 2019
    Nice work! I’m not sure how much arch they should have. Maybe you’ve already mentioned it but are they original/stock springs? I’ve had bad luck buying aftermarket springs that are supposed to be stock replacements, but aren’t even close. I haven’t replaced the bushings on my T/A yet but when I replaced the ones on my ‘67 Nova the shackle bolts could only be installed in one direction because of limited clearance, if that makes sense. Did you find the same thing on your Camaro?
  6. Allison Winn
    Allison Winn Member
    78
    9
    Jan 10, 2021
    Yes. Had to take off both shackle nuts. With too much arched springs, NEITHER bolt will come out. The gas tank is 1/2" from the lower. Take off both nuts then leave 1 shackle and take 1 shackle to get spring out.
    My originals have 9-5/8" free arch and that is way too much - the most liked replacements have 8-1/8" for stock ride height.
  7. T/A Tom
    T/A Tom Member
    37
    20
    Apr 29, 2019
    Wow, that seems like a lot of arch!! Do you know if they’re supposed to be stock GM springs. Again, sorry if I missed that somewhere in the thread. If you could post some before and after pictures of the car’s ride height that would be great. Should be quite a difference!
  8. Allison Winn
    Allison Winn Member
    78
    9
    Jan 10, 2021
    100% originals. This pic though without motor and trans and interior, only pic I have. But you get the idea - this is sitting with shocks topped out - undo the shocks and it goes up another inch 20201114_094625.jpg
  9. K1ng0011
    K1ng0011 Veteran Member
    192
    31
    Mar 22, 2014
    United States
    My leaf springs were original I could not remove my gas tank and had to sawzall the leaf springs shackle bolts. When I took off the ubolts on my passenger side leaf springs I found out they were all broken in half.
  10. Allison Winn
    Allison Winn Member
    78
    9
    Jan 10, 2021
    Wow. Bolts broken in 2 sounds scary
    Since that pic was taken I installed motor trans exhaust and gas tank and was still sitting topped out on shocks
