Leaf spring hardware question
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 80's AL, Feb 14, 2019.
  1. 80's AL
    80's AL Member
    72
    21
    Sep 23, 2017
    Dallas, GA
    I am about to replace the rear springs on my 80'.
    I was going to do 4 U-bolts rather that the 4 T-bolts and 2 U-bolts.
    Is there any advantage/disadvantages to this?
    Thanks
  2. 79T/Aman
    2,628
    247
    Oct 7, 2004
    Dickson TN.
    not at all, we provide four 1/2" U-bolts in our kits.
  3. 80's AL
    80's AL Member
    72
    21
    Sep 23, 2017
    Dallas, GA
    I really like the roll bar you guys have as well.
    on my wish list....sure i will be getting one at some point.
  4. Twisted_Metal
    29,066
    2,123
    The only disadvantage.... You will need to drill out the holes for 1/2" U-bolts. (originals are 7/16")
    You will also need to bend the brake lines a bit to put the u-bolts beneath them.
    John Wright and 72BIGBLOCK like this.
  5. badazz81z28
    20,151
    1,279
    Alabama
    I would just get replacement 7-16 u-bolts. Hotchkis provides 1/2” bolts but it was a PIA over sizing all the holes.
  6. John Wright
    15,143
    371
    Aug 9, 2002
    Rustburg, Va
    You can pick up a 9/16" drill bit and open those holes up in a matter of seconds per hole. Just be easy with the hard brake line and slip the U-bolt under it. Easy stuff and better than the factory T-bolts IMHO.
  7. Coadster32
    2,171
    307
    Oct 2, 2013
    Milford,CT
    I also went with 4 U-bolts. Mine is just a street car, buit I at least got better piece of mind from it.
