Leaf spring set up questions
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by J. Chris Davis, Oct 31, 2013.
  1. 79T/Aman
    2,628
    247
    Oct 7, 2004
    Dickson TN.
    no the Comp uses different springs as well
  2. J. Chris Davis
    J. Chris Davis Veteran Member
    850
    49
    Jul 13, 2004
    Dixon, IL USA
    How do the comps work with the Hotchkis front springs? I know you said they go with the GT set up, but I wasn't sure about the comp set up. Also how are the comps for driving on the street? Are they pretty stiff compared to the GT set up?
  3. 79T/Aman
    2,628
    247
    Oct 7, 2004
    Dickson TN.
    the Comps use the spherical bearing, this reduces bind so the leaf spring must be stiffer to compensate, so it will still ride well but it is able to handle more load, the comp leafs are only about 15% stiffer.
  4. J. Chris Davis
    850
    49
    Jul 13, 2004
    Dixon, IL USA
    So the Comp leafs like the GT leafs will work fine with the Hotchkis front springs I have?
  5. J. Chris Davis
    850
    49
    Jul 13, 2004
    Dixon, IL USA
    I think I'm going to do this. I have the Hotchkis new in the box and it looks like I can still return them for a full refund. I think I may do this and then just get the whole PTFB Comp set up with front coils. I think that's probably the wiser choice. Then I have all matching pieces. I will be ordering in about a month maybe two depending on holidays. I thank you all again for all of the information and especially Dave.
