Leaf Spring/Shock Bracket Cracked
Discussion in 'Troubleshooting & Diagnosis' started by Blk+Orange79Z28, Mar 12, 2018.
Tags:
  1. John Wright
    14,841
    249
    Aug 9, 2002
    Rustburg, Va
    There is a good chance that the radial burst crack has been there since the day it was pressed into shape.
  2. CorkyE
    10,640
    590
    Was kind of wandering that myself. As old as it is, and if it was going to be a problem, that crack would be much larger by now.
  3. John Wright
    14,841
    249
    Aug 9, 2002
    Rustburg, Va
    If I'm thinking about this correctly and the shock plate is upside down in the picture....and.... If air shocks caused that crack, I would think the car would have had the suspension in a quick droop situation hyper extending the shocks(car was airborne).
    The weight of the car just sitting on the air shocks would have put that crack in compression so it would have never grown unless the suspension was in droop placing that crack in tension.
  4. Camarolina
    Camarolina Veteran Member Lifetime Gold Member
    925
    332
    Jun 12, 2009
    Unionville, NC
    This.^
  5. autobahn
    autobahn New Member
    29
    Jun 8, 2005
    55963
    just put a flap sanding disc on your 4.5" grinder and smooth out til the crack is gone ,then finish up by smoothing all the rough edges ,cracks can't grow if there is no where to start
  6. Bandit723
    Bandit723 Veteran Member
    3,194
    474
    Oct 1, 2016
    Waupaca WI
    Hmm...where have I seen this before
