LED can lights, wiring wrong?
Fbird
6,210
atlanta, ga
were you just replacing OLD cans with LED?
Or
did you ADD cans to an existing circuit
OR
did you add an entire circuit (switch and cans)
30,834
If they are new LEDs, they could be defective.
Try switching the "bad" ones to another circuit where the LED bulbs are working.
FreedomPenguin
1,561
Dayton, Ohio
I hard wired my leds, and had an issue where they wouldn’t run properly. I had 4 run succession/parallel. Found out one of them was reversed wiring causing all 4 of them to not power on.
I figured it out going through each one and testing.
Mine indeed did matter reversing, but I wonder if it’s because 3 was correct and one was backwards I guess that could mess it all up
