LEFT VENT CONTROL DOES NOT WORK
Discussion in 'Troubleshooting & Diagnosis' started by JUNKYARD AUTOCROSSER, Oct 15, 2020.
  1. JUNKYARD AUTOCROSSER
    JUNKYARD AUTOCROSSER Member
    47
    15
    Nov 16, 2009
    Los Angeles, CA
    Hi. I have a 1971 Z28 Rally Sport and my passenger upper vent control does not work. The knob slides in and out but the flapper does not move. Any advice would be appreciated. Thanks and stay safe.
  2. grzewnicki
    3,505
    216
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Pretty simple system, knob + cable + f;apper door. Easy to pull the pass side kick panel, door sill plate comes off, then a bunch of phillips head screws hold the kick panel to the car body. It will be a little hard to pull, they use a putty to seal the duct to the car, just pull and wiggle a bit. Pretty sure repros available or buy used on ebay if the cable is broken. Could be attachment point where cable is connected to door. You won't know till you pull it apart.
  3. JUNKYARD AUTOCROSSER
    47
    15
    Nov 16, 2009
    Los Angeles, CA
    Thanks for your suggestion, I will try it. take care and stay safe.
  4. TommyRS70
    TommyRS70 Veteran Member
    1,289
    146
    Jan 31, 2004
    KY
    Passenger side fairly easy....driver side pain in butt. Emergency brake lever needs removed. Both have plenum sealant that needs persuasion to pull the kick panel out of chamber. Simple mechanism once exposed. Good luck on you journey!
