Long tube frame mount tranny coolers
Discussion in 'Transmission & Driveline Topics' started by chevysrule454, May 16, 2011.
  1. Last edited by a moderator: May 16, 2011
  2. doc221978
    doc221978 Veteran Member
    355
    Nov 29, 2008
    Allenhurst, GA.
    It seems like it wouldn't get enough airflow. On my '78 F150 I am using an old AC evaporator. It keeps the C6 cool with no problems at all. Just an idea, but it works.
  3. GoldenOne7710
    5,612
    894
    Jun 23, 2004
    Athens, GA
    Definitely not enough air flow. That might be OK for a T-Bucket or other hotrod roadster that doesn't weigh all that much. For a 3300lbs + car with that much stall.....I wouldn't bother. You need a cooler in front of the radiator so it gets all the air it can.
  4. Twisted_Metal
    30,173
    2,882
  5. camaro19791000
    camaro19791000 Veteran Member
    103
    Feb 28, 2009
    El paso Texas
    a similar cooler came out on spike tv's extreme 4x4 and they "so possibly" ran it on a rock crawler without any over heating issues
  6. The problem with that cenario is in rockcrawling as a rule uses the lowest stall available to minimise slip and consequently keep heat down and work the engine in its lowest tourque band. That type of cooler was probubly enough to keep that tranny cool. My problem is I need enough cooling to keep a 3700 stall on the street, cool.
  7. If I went with something like this here cooler,would I need a small fan as well?I dont want to be experimenting when im on the road ,Id rather figure it all out on paper first.I cant afford any mistakes.
  8. Twisted_Metal
    30,173
    2,882
    Mine is mounted in front of my radiator... No additional fan.
    I used spacers to set it off the back side of the horizontal bar between the bumper and radiator support. (78-81 front end)
  9. Are u runnin a high stall as well?
  10. Twisted_Metal
    30,173
    2,882
    Not a very good comparison to my car.
    I'm running a higher stall than stock (22-2400) and cruising at far below stall speed. (200-4R, Lock-up converter)
    Using an even larger cooler won't hurt anything.
    My suggestion.... See what you have for space to mount it and get the biggest one which fits. (Hayden, plate style)
