Looking for 8.5" 10 bolt rear end differential rebuild options
Discussion in 'Transmission & Driveline Topics' started by Mr Sunshine, Jul 5, 2020.
  1. Mr Sunshine
    Mr Sunshine Veteran Member
    129
    17
    Dec 12, 2016
    Missouri
    Thanks for the link, that's a really good process shown. I have a little experience with nickel welding and a lot with Tig. My main concern is with keeping the axle straight. Have you ever had issues with the axle warping or loosing straightness? Or do you plan to straighten after the weld process?
  2. camaro71/holland
    1,492
    195
    Aug 27, 2003
    The Netherlands
    It will warp. You can minimize it by doing short runs a time and going from side to side.
    Then you need a jig and a torch get it straight.
  3. badazz81z28
    20,582
    1,386
    Alabama
    I have a tru-track...I vote Eaton posi for a street/strip car. The tru-trac is a autocross preference, but I hate it everywhere else.
  4. BonzoHansen
    20,716
    1,794
    Jun 1, 2005
    Scott from Hamilton, NJ
    Why? I have no issues driving mine.
  5. badazz81z28
    20,582
    1,386
    Alabama
    I just don't think the wheel lock-up is immediate like a posi. If I go out and driving and hit the gas, both wheels don't immediately propel me. When I had a posi, it felt much better at the strip and aggressive straight pulls on the street.
  6. Fbird
    5,531
    1,494
    Feb 12, 2011
    atlanta, ga
    things that make you go HMMMm... interesting
  7. Mr Sunshine
    129
    17
    Dec 12, 2016
    Missouri
    OK so I decided to repair the existing plugwelds holding the axle tubes in the rear housing because they had noticeable pin holes and the weld was not completely sealed around the edge on a few. As soon as I hit them with the Tig torch at 165 amps they opened up showing a lot of porosity within the weld. I don't know how common this is, but my guess is that this could be the reason why some axles break loose under high torque. I got a full weld puddle going and eventually worked out all the porosity. I used stainless steel filler wire. Once I got the area clean of all rust it flowed well and fused with the housing.
    IMG_20200801_110104976.jpg IMG_20200801_110856261.jpg IMG_20200801_113010849.jpg IMG_20200801_131212263.jpg
  8. biker
    biker Veteran Member
    3,461
    1,546
    Dec 7, 2014
    Nice work!
  9. Bandit723
    Bandit723 Veteran Member
    3,531
    621
    Oct 1, 2016
    Waupaca WI
    So are you saying you prefer a locker on the street vs a limited slip
