tims78camaro
looking to buy a air compressor. see alot i like but the problem is you got to have 220 outlet. is there a good one that wont run alot when using air tools doing body work that not a 220
Depends on what you want to run with the compressor. Basic air tools like an impact wrench or to pump up tires you can get away with a 110V compressor with a 60 gallon tank. Wait for thew tank to pump up and then use the impact. For other things like a HVLP paint gun or a DA or a blast box or just about anything else you need 220V. Even then not a small 220V or it will run constantly Look at the amperage draw. A true 5HP will draw about 22-24AMPS at 220V. I run mine on a dedicated 30 amp circuit. Wire size will depend on distance from the breaker.looking to buy a air compressor. see alot i like but the problem is you got to have 220 outlet. is there a good one that wont run alot when using air tools doing body work that not a 220
