Looks like I am Going Racing This Sat.
Discussion in 'High Performance Modifications' started by 1980RS, Jun 4, 2020.
  1. 1980RS
    1980RS Veteran Member
    4,092
    992
    Jun 17, 2006
    MN
    The track is open, the air will be good so I am going out to beat the crap out of the 406 with "stock" Vortec heads. Here's what's in it.
    .030 400 sbc around 11 to 1 compression
    Stock 906 Voretc heads with my own 3 angle valve job. Stock rockers
    Scat crank and 5.7 rods (forgot to clearance them) as the scat ones were junk.
    Elgin 1165P cam .488 .510, 234° and 244° on a 106 LCA
    GMPP (RPM style intake)
    1 5/8" headers
    A whole bunch of carburetors, 850 Mighty Demon to start with.
    10 Jeg's 4100 stall converter.
    Turbo 400 with 4.10 gear.
    Peanut port engine with all else the same ran 11.78@113mph best.
    What do you think this combo will run? I am saying 11.60's@114mph. The heads are the big if factor here, have never used a set at the track on a decent short block.
    2ndOwner78 likes this.
  2. budro6968
    budro6968 Veteran Member
    3,680
    671
    Apr 2, 2016
    Jax Florida
    Who cares? Just pound that Engine and please post some pic's so we can all live vicariously through your effort. I hope it will live.
    Big Block Z and Zstar like this.
  3. biker
    biker Veteran Member
    1,453
    344
    Dec 7, 2014
    New Liskeard Ontario Canada
    Yes. Good luck to you man. Been hoping to hear how this will run for you.
  4. muscl car
    22,279
    1,053
    Jul 8, 2001
    SoCal High Desert
    Have fun , I'm thinking easy 11.50's
    I wish the tracks here would open up so I could see what my new 427sbc will run
  5. Z28-79
    Z28-79 Veteran Member
    117
    9
    Mar 22, 2016
    EAU CLAIRE WI
    Is Rock Falls open?
  6. xten
    xten Veteran Member
    3,490
    2,290
    Sep 24, 2014
    Pittsburgh, Pa.
    Curious to see ET vs MPH with the 906 Vortecs. I'll go 11.40's @ ~117. Kid's best in a stock weight 3rd gen with same setup except heads and headers was 10.91 @ 119. Pro Topline CNC 235 heads, Stahl 2" primaries. Good luck.
  7. G72Zed
    G72Zed Veteran Member
    1,587
    507
    Sep 8, 2015
    Good that your getting out to test this. Seeing that your loosing a couple of hundred pounds, I'll say 11:50 @ 115.
    What is your starting line weight 1980RS ? , regardless, your ET to MPH ratio is almost bang on the money, nice setup, your getting everything out of it.
  8. tom3
    tom3 Veteran Member
    12,593
    607
    Aug 1, 1999
    ohio
    For some reason I'm not on board with these guesses. I'm at 12:30 @ 120 or so. Prove me wrong and have fun!
  9. BillyDean7173
    BillyDean7173 Veteran Member
    2,102
    609
    May 21, 2014
    Hutto, TX
    Good luck, be safe, and trailer some fools!:D
  10. C4Racer
    C4Racer Veteran Member
    670
    126
    Oct 26, 2018
    Ya the vortecs don't flow all that great - what maybe 225ish? I think you might break into the 11's but not sure you will see a 11.5 from that set-up.
