Lovin atomic efi so far.
Discussion in 'High Tech Retrofits' started by DMSTAINLESS, Jun 3, 2012.
  1. DMSTAINLESS
    DMSTAINLESS Veteran Member
    516
    Sep 19, 2010
    ILL
    Well some of u guys wanted to know...
    Msd efi is installed and have about 30-40 mi on it and it is for the most part awesome! The throttle response is awesome it revs like a crotch rocket! Just blip the throttle and the needle jumps 15grand and that's in gear runnin down the road. And starting, wow! love that just reach in the window and bump the key, vroom, hot or cold every time. Power curve seems to b a straight line pull all the way to red line, no more secondary surge. Install was easy depending on how u do ur install. I chose to go for dependability with an in tank pump and it's great so far, cept I need to drop tank again, fuel gauge may b hung up on pump module. Hand held unit seems handy and easy, but I have no experience with any others. Overall I'm very happy and the more I drive it the better it gets because it continuously learns. My only issue is my IAC pos seems to b jumping around but I'm sure a lil talk with a tech tomarro and we will have it dialed in or because my cam fell on the fence between mild and performance I may chg that setting.
    Anyway I love it
    My tires hate it!
  2. earnhardtgm3
    earnhardtgm3 Veteran Member
    3,972
    51
    Dec 18, 2007
    Camaro Country,GA
    Great to hear
  3. DMSTAINLESS
    516
    Sep 19, 2010
    ILL
    Few pics
    Pump module from tanks inc. very nice unit.
    In the tank
    Getting wiring routed
  4. 73Camaro383
    73Camaro383 Veteran Member Lifetime Gold Member
    2,288
    Oct 29, 2010
    texas
    I'll trade you a slighly used 650 eddy for your AVS? lol
  5. DMSTAINLESS
    516
    Sep 19, 2010
    ILL
    Still havin trouble? That sux. I'm lovin this efi, no tuning for I only knew enuf to get myself in trouble.
  6. earnhardtgm3
    3,972
    51
    Dec 18, 2007
    Camaro Country,GA
    DMSTAINLESS
    Where did you put your O2 sensor bung for your EFI setup?
  7. DMSTAINLESS
    516
    Sep 19, 2010
    ILL
    Well I had trouble with clearance so even tho I didn't want to I followed the directions and at first put it in the rear cylinder primary header tube, but I was reluctant to only read one cylinder, so I moved it just past the collector joint in the pipe. To do that u really need to make sure u have no leaks.
  8. 73Camaro383
    2,288
    Oct 29, 2010
    texas
    I only need to figure out why it dies out on hard stops.. Other than that it doesnt run bad. I got my 600 back on the car for now.
  9. weircc
    weircc New Member
    23
    Jan 9, 2010
    richmond mo
    how would you say your gas mileage is better or worse or same??
  10. Z-WIZZ
    Z-WIZZ Veteran Member
    1,297
    Mar 18, 2004
    FLA
    and, what was total installed price?
