Lowering rear with lowering blocks
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Chevy70, Oct 1, 2014.
  1. Chevy70
    Chevy70 Veteran Member
    313
    Mar 3, 2014
    WA
    Lowering rear with lowering blocks vs lowering leafs
    Hey guys, been reading on how to lower the rear of the camaro...
    Lowering blocks $20-30
    Lowering leafs $190 (summit)
    What are the pros and cons? Is one easier to install then the other?
    I should point out I do have traction bars...
    I noticed on dips in the road my front end feels like a boat, much stiffer spring is needed and or the stock ones are probably toast. Any recommendations ?
  2. Dogwater
    Dogwater Veteran Member
    926
    Dec 23, 2010
    SanAntonio Tx
    I personally wouldn't use both might make it to low, especially with slapper bars. I'm using regular but stiffer leaf springs an I made my lowering blocks out of an aluminum street sign. I think it about 1/2 in thick. Goes where that rubber pad is between the perch an leaf spring. I wouldn't use the a rubber pad either if your using a lowering block. The rubber pad makes it harder to keep proper torque on the 2 or 4 long U bolts. I have lowered front springs also but almost any mid high speed bump I drag on them.Maybe lowered leafs first then if its not low enough for you get the blocks. The blocks are easier to put in. If you look where the blocks mount you'll see how easy it is to make your own. I just stacked 4 pieces of aluminum street sign that I cut with a jig saw, an drilled a 1/2 in hole in 2 of them to index on the leaf.
  3. JWZ28
    JWZ28 Veteran Member
    1,239
    Feb 27, 2011
    Alabama
    Let me know if you decide to go with lowering blocks, I've got a set of 1in lowering blocks for sale on here for $15 + shipping. Just shoot me a PM if interested.
    As far as pro's and cons, I'm not sure you'll really tell a difference since the rear will be on leaf springs either way. You're just swapping springs with one and displacing clearance with the other. I went with eibach lowering springs up front. They're nice and stiff, but ride well too
  4. CorkyE
    11,180
    822
    I realize it the less expensive route but I'd be real weary of using lowering blocks with slapper bars.
    As for the front, sound like a good set of shocks are needed.
  5. Rockhound
    Rockhound Veteran Member
    158
    Dec 3, 2007
    tennessee
    Totally agree with this....
    I have never been a big fan of lowering blocks in a performance application, whether it be a drag oriented build or a corner carver.
  6. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    A lowering block increases the ability for wheel hop as it moves the axle further
    away from the spring. So even with slapper bars ..
    The Hotchkis rear springs will lower your car and should allow the removal of the
    slapper bars. They resist wheel hop. So far .. zero wheel hop with them.
    Tom
  7. Chevy70
    313
    Mar 3, 2014
    WA
  8. formulajg
    formulajg Member
    53
    Sep 9, 2012
    Toronto, Canada
    I lowered the rear of my Firebird like this:
    Been driving it like I stole it for several months now with and no problems at all.
