Lowering Springs
Discussion in 'Troubleshooting & Diagnosis' started by valleyguy, Jul 23, 2020.
  1. RickM
    RickM Veteran Member
    618
    105
    Apr 16, 2004
    Gaithersburg, MD
    Your car looks great as it is, don't do it. I like the stock look.
  2. hubedobeedo
    hubedobeedo 3rd times a charm
    614
    223
    Jul 18, 2013
    Huntertown,IN
    ye i put 350 pounds of weight in there and didn't rub ,still had good clearance. now to finish and put the total in and see what i got not to worried though. thanks for the response .o ye the weight i put in i had it in there for about 3 months kinda got distracted on other things .
  3. smokeatr23
    smokeatr23 Veteran Member
    237
    10
    Dec 24, 2014
    United States
    I know this is an old thread but, was wondering if you have trouble with your front tires rubbing on bumps. Mine is at least ½" higher than yours and on small bumps. I have 2" lowering springs and new monroe shocks. Maybe better stiffer shocks?
  4. carr911
    carr911 Veteran Member
    3,499
    3,393
    Mar 4, 2016
    Tampa, FL
    after Testing the Lowering Springs, I then went to Viking Coilovers on all 4 Corners
  5. John Wright
    15,172
    388
    Aug 9, 2002
    Rustburg, Va
    Be aware of your alignment as camber can tilt the top of the tire in during compression and keep it from rubbing on the fender liner bolts provided the back spacing of the wheel and tire size is okay.
  6. smokeatr23
    237
    10
    Dec 24, 2014
    United States
    That could be part of the problem since I did just replace the upper control arm shaft with a correction shaft because I had a huge camber issue on one side. It rubbed before though with way too much camber. I think my monroe shocks are just garbage and let the suspension
    compress too quickly.
