LS Swap- Gas Pedal, Throttle cable and brackets
Discussion in 'High Tech Retrofits' started by Dcmusch, Feb 6, 2017.
  1. Dcmusch
    Dcmusch New Member
    27
    Aug 21, 2014
    San Antonio, tx
    I know there are some posts on these items. I've gotten some conflicting information on which ones to get. If you could please share some part numbers and setups so I make sure I order the right parts. Thanks in advance. FYI, I dont have the stock gas pedal.
  2. paintman65
    paintman65 Veteran Member
    181
    9
    Jan 8, 2012
    Brenham TX
    On my swap I used the cable that came from the 2000 Tahoe that was my swap donor.
    It hooked right up to my 81' factory pedal. The hole in the firewall had to be enlarged just a little but that's it.
    I'm using the truck intake but it should work any of the car intakes too.[​IMG]
  3. badazz81z28
    18,836
    989
    Alabama
    LOKAR cable and stock pedal. The cable is universal for LS engines. I might be able to dig up the part #. It will be a trim to fit set-up
