LS Swap-Lower Radiator Hose
Discussion in 'High Tech Retrofits' started by Bill70, Feb 2, 2015.
  1. Bill70
    Bill70 Veteran Member
    236
    19
    Jan 8, 2012
    Phoenix, AZ
    I am posting this for those people who find themselves wasting a lot of time trying to find a good fitting lower radiator hose for their LS swap. I read every post and bought a few of the recommended part numbers to no avail. I realized that not every LS swap is the same. Key differences are the thermostat housing (early or later years) and radiator selection (26" or 31" wide). My car has an Edelbrock pump and 31" Griffin LS swap radiator (1.5" id hose). I spent about an hour or so looking through the online Dayco catalog and found #71391. The picture looked promising so I bought it today and it fits like a glove after trimming about an inch off each end. Hopefully this helps someone with their swap.
  2. Da-bigguy
    4,917
    832
    Jan 19, 2010
    Cypress, TX
    That does look good. What do you think of the radiator? I'm going to be in the market for a radiator to cool my LS7 once I start putting everything back together.
  3. Bill70
    236
    19
    Jan 8, 2012
    Phoenix, AZ
    I chose the Griffin radiator for a few reasons. I have been running one is my big block Chevelle and it cools a lot better than the 4 row copper/brass radiator. I liked the fact that it is a dual pass radiator with the steam fitting included. Also, it has 1.25" and 1.5" hose attachments which match my water pump. I figured that would make finding hoses a bit easier. Finally, this was about $250 vs $500 and up for everything else.
  4. hot72rod
    3,019
    39
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    I've been looking at the same brand rad. to put in my car. Will you post up the part number of the rad you used?
  5. Bill70
    236
    19
    Jan 8, 2012
    Phoenix, AZ
    I purchased 8-00010-LS. This does not contain a transmission cooler. There is a different part number if you need that.
  6. hot72rod
    3,019
    39
    Aug 9, 2000
    I'm running an auto, but I'm still not sure if I want to run a rad with a built in trans cooler or run a stand alone unit.
  7. mrvedit
    mrvedit Veteran Member
    1,355
    Jun 12, 2009
    Ann Arbor, MI
  8. 70PTRS
    70PTRS Veteran Member
    257
    Aug 23, 2013
    Northern Illinois
    Very sweet setup. I'll keep that hose number in mind. I'm going to attempt to use an '02 fbody radiator and fans.
  9. badazz81z28
    18,668
    952
    Alabama
    What part number are you running for a top hose?
  10. Bill70
    236
    19
    Jan 8, 2012
    Phoenix, AZ
    I believe it is Dayco 71951. I had to trim both ends to fit properly.
