LS Swap (LS3 with a T56)
Discussion in 'High Tech Retrofits' started by Fume, Jun 21, 2020.
  1. Fume
    Fume New Member
    11
    Jul 4, 2019
    Is a T56 going to fit in a 1973 4 speed manual?
  2. dave@ztech
    4,066
    883
    Mar 27, 2016
    NY
    Easy answer, yes. It will take a new shifter hump , I believe Holley has a great one.
  3. BonzoHansen
    19,955
    1,268
    Jun 1, 2005
    Scott from Hamilton, NJ
    It will. You may need to some cutting depending on the mounts used and engine placement.
  4. badazz81z28
    18,010
    778
    Alabama
    I have a magnum in my 70, minimal cutting and a little massaging. Fits better than a TKO did. I have a hooker shifter hump I didn’t use, if interested.
    76z28 likes this.
  5. 76z28
    76z28 Veteran Member
    2,121
    63
    Jun 29, 2009
    bakersfield
    Right there with Badazz--- I have a big block with a magnum, minimal cutting!--about the size of a postcard for the shifter to come through.
  6. TCinthe6
    TCinthe6 Veteran Member
    131
    40
    Nov 5, 2017
    Toronto, Canada
    No issue fitting. My T56 and LS3 work extremely well together. Only problem I have is the lower part of the bell housing has bottomed out a few times, but that's likely because my car is sitting lower than I like.
