LS1 Spark Plugs - what you guys run?
Discussion in 'High Tech Retrofits' started by sbca96, Jul 2, 2014.
  1. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    So, I got the valve seals done, grommets, seals, valve covers and bolts torqued.
    Time for plugs. The ones I took out are AC Delco #12, I see that AC Delco #6 is
    recommended with a gap of .40 rather than the #12's gap of .60. Seems that it
    was changed by GM in 2003, gap went from .60 to .40. The #12's lasted 125k so
    I am tempted to just get them again, but the gap bothers me - so go #6?
    I know there is talk of NGK, but since this is SUCH a pain to get too, I don't want
    to skimp or open myself up to fouled plugs.
    Granted the above part numbers are for Iridium, and I do not have the income to
    support that price hike. Seems the AC Delco #6 is a mid-level long lasting plug.
    Tom
  2. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    I use the plugs my crate engine came with. I think they are 2004 Corvette AC Delco plugs...500hp, runs mids 11s. Plugs don't need to be high dollar pieces. OEM works.
  3. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    So that is the AC Delco Iridium plugs then? I'm leaning toward a Rapid Fire with
    the miles I have on the engine, I doubt it will see another 100k ... but is that a
    #12 or a #6? Autozone claims the #12 is wrong for the engine, though that is
    where I bought them from. Oreillys shows the #12 as an option. So gap wise the
    "correct" plug is the #6 from the GM bulletin.
    AC Delco copper is 2.30 a plug or 1.80 with rebate.
    AC Delco rapid fire platinum is 4.99 a plug or 3.99 with rebate.
    AC Delco double platinum is 6.50 a plug or 5.00 with rebate.
    AC Delco Iridium is 6.99 a plug or 4.99 with rebate.
    Tom
  4. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Autozone had 7, Napa had 4 .. Orielly had 9 .. and on sale for 3.99. I should get
    another dollar off that with the rebate : which goes on all year BTW.
    So. Installing #6's today.
    Tom
  5. Bumpad_Z28
    Bumpad_Z28 Veteran Member
    500
    Apr 9, 2004
    Logan, UT
    NGK's
  6. 70PTRS
    70PTRS Veteran Member
    257
    Aug 23, 2013
    Northern Illinois
    ^^^^^^ What he said
  7. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
  8. Randy S
    Randy S Veteran Member
    164
    Mar 27, 2008
    NELA
    I run NGK TR55's.
  9. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    GM engineers obviously decided to improve on the design, but your experience proves the existing plug also works to 125K.
    Either choice would be good I'm sure, and I'm also an NGK guy but factory plugs are obviously proven to work well.
  10. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Well, I'm sure that NGK plugs work fine, perhaps even better than AC Delco, but
    my concern is how long they last. A candle that burns twice as bright lasts half
    as long. Most you guys look at the MOST you can get in HP, I just want decent
    power (fun factor) and longevity.
    Tom
