LSA in '72 Z28
Discussion in 'High Tech Retrofits' started by gnx017, Jan 30, 2017.
  1. gnx017
    gnx017 New Member
    9
    Mar 7, 2010
    Monsey, New York
    Greetings,
    I just purchased by Brother-in-laws totaled 2012 CTS-v (rain, no traction control, 3 martinis), I am considering swapping the LS-A / T56 into the '72 z28, I have the parts and materials list I need, how much cutting will be required. This a 30K mile vehicle, non-matching engine.
    I have the budget to do so, since I bought the vehicle for $4500.
    Thanks,
    Stratos
  2. 70 gsconvt
    70 gsconvt Veteran Member
    1,095
    Sep 30, 2009
    Wadsworth, OH
    You got the Caddy for $4500 !?!?!?!? WOW! That's a steal if you did.
  3. gnx017
    gnx017 New Member
    9
    Mar 7, 2010
    Monsey, New York
  4. gnx017
    gnx017 New Member
    9
    Mar 7, 2010
    Monsey, New York
  5. gnx017
    gnx017 New Member
    9
    Mar 7, 2010
    Monsey, New York
    Any suggestions with shops in the NY/NJ area who can the install?
  6. nobreaks254
    nobreaks254 Veteran Member
    519
    13
    Jul 14, 2007
    aberdeen, SD
    Are you using the brakes?
  7. gnx017
    gnx017 New Member
    9
    Mar 7, 2010
    Monsey, New York
    Not sure, can they be converted the '72? If not, are you interested?
  8. gordonquixote
    3,022
    11
    Jul 18, 2006
    Tallahassee, FL
    You will need an Fbody oil pan and likey a different front pulley setup.
    Also will need a gas tank conversion, motor and transmission mounts.
    A modified wiring harness would simplify the process if not a DIYr.
  9. 70 gsconvt
    1,095
    Sep 30, 2009
    Wadsworth, OH
    You may also have issues with the shifter placement. I'm pretty sure it's not going to come up in the same hole. And the tunnel may need to be cut open to accomodate the much larger than stock transmission case. And you'll need a custom driveshaft with T56 end/slip yoke.
  10. BonzoHansen
    20,809
    1,835
    Jun 1, 2005
    Scott from Hamilton, NJ
    I'll give you $5500 for that ctsv
