sevitz5
I have compiled this list of what I have bought for my conversion, and have tried to list part numbers and where to purchase. I hope this helps someone looking for a part.
Here goes:
2001 Silverado 2500 6.0 30,000 miles...Local Junk yard $700
2006 GTO T56 6 speed 10,000 miles...Local junk yard $1,700
Texas Speed MS4 Cam (239/242 .649/.609)....25-MS4 $400
LS6 Intake with fuel rail....Ebay or LS1Tech $400
LS2 Timing chain...GM Dealer 12586482 $75
Texas Speed LS6 ported oil pump...25-LS6PORTEDPUMP $190
1999 Fbody oil pan,win tray, pickup tube...GM dealer $350
Car Shop 1" setback motor mount plates...CSP2370 $50
2000 Camaro alt...NAPA NNE-1N4742 $180
2000 Camaro harmonic balancer...NAPA NOE 6005281 $65
2000 Camaro water pump...NAPA TFW 45002 $130
EFI Fuel Tank...Rock Auto GM42AFI $375
2000Corvette fuel filter w/return...Ebay, Wix 33737 $40
Fitting's for fuel filter...Russel...640850, 640860, 640940 $45
LS1 polished throttle body...Ebay (swap program you send him yours) $60
Pushrods...Texas Speed 25-7400 $90
Heads 243 casting w/.650 springs....LS1Tech $675
LS7 Clutch press, flywheel....LS1Tech $260
Tick Performance adj clutch master cyl...TAMCKFB $325
Tick Performance slave and throwout bearing...24264182 $130
Tick Performance speed bleeder...TPSBL $50
Allen head Engine bolt kit...Ebay $35
Allen head Intake bolt kit...Ebay $30
Stand alone wire harness....Done by local guy $200
Clutch master cly mounting plate...Detroit Speed 070430 $30
Serpentine belt...O'Rileys...Gates K060547 $20
Idler pulley...O'Rileys..38008 $15
2000 Camaro Belt Tensioner...NAPA NBH 38195 $43
Upper radiator hose...NAPA Gates 22352 $20
Lower radiator hose...NAPA Gates 20734 $13
2000 Camaro starter...NAPA BSN SR8581N $180
2000 Camaro Thermostst...NAPA THM 400186 $16
Spark plug wires...Jegs Taylor 10.4mm $90
Spectre Performance cold air kit...900134 $208
G-Force crossmember....RCF2E-T56 $290
Texas Speed Racetronix 42lb injectors...135-01D030X-1 $350
Flywheel & pressure plate bolts...Jegs $62
Oil catch can...Ebay $40
-6AN Fuel line and fittings...Aeroquip $220
Lokar throttle cable...Jegs TC-1000LS!U $55
Lokar oil dipstick...Jegs ED-5008 $58
Lokar Throttle brkt...Jegs TCB-40LS13 $38
Valve cover breather...Metco Motorsports MBR0003 $35
2000 Silverado 2500 oxygen sensors (2)...NAPA BSH-13026 $110
Fuse block for fuel pump, fans, etc...Local junkyard 99 Monte Carlo. $20
LS7 MAF sensor....GM Dealer 15865791 $70
Shorten driveshaft to 44 5/8"...Local shop $130
4.10 rear gears...Summit $187
Headers and exhaust....Stainless Works.
I hope someone can use this list, I wish there was a list like this before I started. LOL.
Here goes:
