Lt door panels to standard
Discussion in 'Interior Restoration' started by 89rodknocker, Apr 21, 2020.
  1. 89rodknocker
    89rodknocker Veteran Member
    607
    Apr 10, 2008
    Fremont, Ca.
    I have a 73 lt and the door panels are shot I want to convert to the earlier 70/71 style door panels. is this possible? If so what all do I need to change over to standard panels?
  2. BillyDean7173
    BillyDean7173 Psychopathy Red
    2,759
    934
    May 21, 2014
    Hutto, TX
    Just to confirm, a 73 Type LT should have the deluxe two-piece door panels with the wood grain inserts in the upper portion and then the lower plastic portion with the two openings for maps and stuff. Is that what you have?
  3. twestrup
    twestrup Veteran Member Lifetime Gold Member
    276
    140
    Aug 22, 2018
    St. George, Utah
    You will need to change a couple of things to make that happen. Could get expensive.
  4. BillyDean7173
    2,759
    934
    May 21, 2014
    Hutto, TX
    The 70-71 arm rest brackets for the lower door panel (the plastic part) are different from the 72 and later lower door panel brackets. Ask me how I know. Also, the deluxe door panel window regulators have a longer shaft for the window handles than the standard regulators.
  5. Twisted_Metal
    29,491
    2,389
    ^ Good info!
    I doubt it will be difficult to find someone to trade your deluxe regulators for a set of standard regulators.
    Your deluxe door panel might be restorable" but that is NOT a cheap process.
    Yours could be worth something to someone as cores for restoration.
    BillyDean7173 likes this.
