LT1 harness
Discussion in 'High Tech Retrofits' started by camaro19791000, Dec 17, 2009.
  1. camaro19791000
    camaro19791000 Veteran Member
    103
    Feb 28, 2009
    El paso Texas
    Want to buy a LT1 engine but it does not have the engine harnest how much do these run?? where can I get one??
  2. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    There are a few sources, "Painless" seems to be the most straight forward
    and easiest to use. There are other cheaper ones though. Approx. $600.
    Tom
  3. mmike
    mmike Member
    63
    Jun 7, 2008
    Aurora IL
    speartech
    has harnness for sale, they are striped down to what you just need. Also they will flash, to remove VCC, and other non use sensors.
  4. drptop70ss
    drptop70ss Veteran Member
    700
    Jul 19, 1999
    NY zip 12538
    I have 3 factory LT1 caprice harnesses that work fine, they have the engine compartment fuse box installed as well. $175 each shipped or $225 shipped with the PCM. One is 1994 and two are 1995, basically the same harness other than the auto trans wiring.
  5. OneShoe50
    OneShoe50 Member
    94
    Dec 28, 2009
    Albuquerque, NM
    FWIT I used a TechRods harness, bought it on fleabay for $450. Was well worth it, was able to order it with the options I needed and I know it's one of the reasons my swap turned out so well.
  6. 130fe
    130fe Member
    50
    May 7, 2006
    Jacksonville, FL
    I might have a painless 60502 available this month. It is used but is in great shape. PM me for more info.
