lt4 HOT Cam Specs
mopar
285
Anderson SC
I purchased the chevy LT4 hot cam for my 350. I received it today. It didn't come with a cam card. I know the overall specs. Does anyone know the valve opening and closing specs?
mopar
285
Anderson SC
I know the lift and duration. Just wanting the actual valve opening and closing events. I can get it when I degree the cam. Just wanted to know what it should be. I guess Chevy doesn't publish it anywhere?
AJ_72
5,129
Chebanse, IL USA
I know you said you know all these, but I'll post them for everyone else to see.
The lift is .525" with 1.6:1 rockers, .492" with 1.5:1 rockers
The duration at .050" is 218*/228*
Advertised duration is 279*/287*
The lobe seperation angle (LSA) is 112*.
I don't know the Intake Centerline (IC or aka ICA). I would imagine it's 4* advance like any other production SBC cam, which would make it 108*, but this is where learning how to degree a cam the proper way pays off.
Input this info in any program like Desk Top Dyon or Engine Analyzer Pro and you can find out all the other numbers.
Mz28att
I ran the above info in Pat Kelly's DCR calculator program and get the following:
Intake open: 30.5 BTDC Intake close: 68.5 ABDC
Exhaust open: 78.5 BBDC Exhaust close: 28.5 ATDC
Hope I did that right and it helps;
MaTt
probizjudi
1,713
Tulsa, OK
OK here are the cam nbrs I have for our GM hot roller:
Lift 488/509 dur 214/222
There was no nbr like .050 given to us.
Can u tell what that nbr. should be? Like .050 or what?
Thx! Am learning a lot!
