Manual brakes on street car
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by biker, May 16, 2021.
  1. dcozzi
    dcozzi Veteran Member
    4,181
    1,168
    May 1, 2002
    Phoenix, AZ
    I have owned my car for 30+ years and had manual brakes since I bought it. They work great and never gave the pedal pressure a second thought. I switched to Wilwood brakes years ago and used a 7/8" MC (IIRC from a '68 Corvette). Works great but needs a proportioning valve because the rears would lock up first under hard braking since the pad surface area on the rears is large. Just make sure you use the top hole in the pedal and a smallish (7/8" or 15/16") MC or you will have to press real hard to stop.
    Recently, I bought a 7/8" MC from Wilwood and it required me to modify the pushrod length. We will see how it is once the car is back on the road.
  2. 67johnny
    67johnny Veteran Member
    291
    18
    Apr 14, 2016
    vancouver
  3. slamin69
    slamin69 New Member
    11
    Mar 6, 2016
    langhorne pa
  4. slamin69
    slamin69 New Member
    11
    Mar 6, 2016
    langhorne pa
    The reason for no power brakes is because on a race car there is no vacuum to supply the booster. I run a 600hp SBC 383 with a 108c/l cam I use a electric vacuum pump to supply my booster and I love power brakes
  5. camaro71/holland
    1,494
    196
    Aug 27, 2003
    The Netherlands
    More on the engine combo please
  6. 70greenZ
    70greenZ New Member
    Jul 27, 2002
    largo, FL USA
  7. 70greenZ
    70greenZ New Member
    Jul 27, 2002
    largo, FL USA
  8. $ Mike 70 Z-28
    $ Mike 70 Z-28 Veteran Member
    1,273
    132
    Nov 7, 2002
    New York, NY
    biker , not a port on the spacer if you have a 1' spacer they have a90* elbow that you put on the manifold the 1' spacer gives enough room for carb to clear the manifold port
  9. Brian H.O. Cornelius
    Brian H.O. Cornelius Breeze
    10
    9
    Jul 1, 2001
    Bonaire, Georgia
    Keep the vacuum assist set up, you need longer stopping distance with manual brakes. New cars stop faster and the way I see kids cutting in and out then jumping on brakes is scary. Manual brakes were not made to handle quick stops in short distance, the vaccume assist is better although they pale in comparison to newer systems.
  10. SPG
    SPG Bumblebee Builder
    1,087
    390
    Sep 1, 2018
    Sacramento
    Oh, I assure you it's not just kids, you should see how both my parents drive, it's terrifying.
