Manual brakes w/s10 discs
Discussion in 'Competition Camaros' started by 89rodknocker, Oct 23, 2020.
  1. 89rodknocker
    89rodknocker Veteran Member
    607
    Apr 10, 2008
    Fremont, Ca.
    Planning switching to manual brakes but need some help.
    What S10 parking brake cables to get since the pics or part number are not on the site.
    Also what manual master to run with a line lock on the brake setup below.
    1LE 12" rotor swap in the front with wilwood d52 calipers
    S10 rear disc swap.
    I've seen a kit online on ebay for around $189 but figured i might be able to piece one together for cheaper than this but unsure on what master.
    https://www.ebay.com/itm/1970-1981-...it-Camaro-Z28-Firebird-Trans-Am-/174073117031
  2. TTR230
    TTR230 Veteran Member
    465
    216
    Aug 1, 2020
    Burlington, Ontario
    Out of curiosity, why would you convert to manual brakes?
  3. 89rodknocker
    607
    Apr 10, 2008
    Fremont, Ca.
    Low vacuum from my engine.
  4. Twisted_Metal
    29,492
    2,389
  5. TTR230
    465
    216
    Aug 1, 2020
    Burlington, Ontario
    Does using the vacuum from the engine for power brakes really affect power that much? I didn't know that was a thing!
  6. Jodi
    Jodi Veteran Member
    809
    522
    May 22, 2019
    Power brakes relies on engine vacuum to work properly.
    This vacuum is produced by the engine and is stored in the brake booster. Once a brake application is made some of that vacuum is used and then the booster gets a vacuum refill (so to speak) from the engine.
    With the engine not producing enough vacuum it won't be able to keep up, so you're power brakes becomes a manual.
    Instead of going manual brakes, I converted mine to Hydro boost...
    G72Zed likes this.
  7. G72Zed
    G72Zed Veteran Member
    2,809
    1,315
    Sep 8, 2015
    If you look closely you will notice on some of the more serious older "muscle cars" that are used on the road course and for Autocross actually using a manual brake setup.
    On/off WOT on an Autocross really tests the power brake setup, and on a road course, with WOT, the last thing you need is the lack of vacuum & reserve driving in deep with a 3.25 pedal ratio...pucker time LOL.
    TTR230 likes this.
