manual to power conversion
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by slayer74, Apr 7, 2014.
  1. slayer74
    slayer74 Veteran Member
    166
    Jan 10, 2014
    yonkers new york
    anybody have any idea how much a conversion from manual to power breakes would cost in a 76 with no power steering,the motor is a 383stroker,dont have all engine specs just yet any suggestions would be very helpful thanks
  2. BonzoHansen
    20,999
    1,932
    Jun 1, 2005
    Scott from Hamilton, NJ
    depends on how much you can pick up used. let's see, you need a steering box, pitman arm, high psi hose, low psi hose, pump, cap, brackets. I'm not sure if you will need other linkage parts like a center link, etc., or steering shaft and/or rag joint.
  3. slayer74
    166
    Jan 10, 2014
    yonkers new york
    thank you scott, not sure yet if i'm going that route,the manual steering is not all that bad but where i live every street is a hill and some are very steep just want to be safe
  4. garyandcindy
    garyandcindy Veteran Member
    1,649
    9
    Oct 20, 2004
    cumming,ga-usa
    You'll need a belt and a pulley also.You maybe able to run two things of the same groove in your pulley.Mine just turns the power steering pump.
  5. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,117
    50
    Sep 22, 2007
    Blind Bay, B.C.
    I would take a reading of the intake manifold and see if you have the minimum 12" of vacuum first. Could save some money and hassle if hydro boost is needed in the first place.
  6. daddio4048
    daddio4048 Veteran Member
    823
    Jan 21, 2013
    Valdosta,Ga.
    I have a 81 complete power steering set up for sale. Will that fit a76 ?
  7. BonzoHansen
    20,999
    1,932
    Jun 1, 2005
    D'oh!!!! I thought we were adding power steering!!!! lol reading fail!!
  8. slayer74
    166
    Jan 10, 2014
    yonkers new york
    thank you all for all your input,picking up the car saturday along with a bunch of receipts,if i remember correctly(that does'nt happen often)the motor is from 1970 i think he said a chevelle,once i get all the specs i'll put them out there and i guess just go from there thanks sean
