Master Cylinder and Booster Advice
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by AlbertaZ28, May 7, 2020.
  1. AlbertaZ28
    AlbertaZ28 Veteran Member
    299
    9
    Aug 17, 2010
    Fort Mcmurray, Alberta
    I have changed the front and rear brakes to 6th Gen Camaro Brembo's and I bought a 2002 Firebird master cylinder and booster. It looks like the 2002 master cylinder will bolt up perfectly to my stock booster. My question is should I change out the booster or use my stock one with the new master cylinder? Is there a benefit to the dual 9" booster?
  2. Twisted_Metal
    30,064
    2,787
  3. AlbertaZ28
    299
    9
    Aug 17, 2010
    Thanks Twisted Metal. I will check that measurement.
  4. badazz81z28
    21,034
    1,485
    Alabama
    Look into Detroit Speeds master/booster. It’s a direct bolt on and designed for 4 wheel disc. It’s a C5/6 set-up
  5. Zee
    Zee Veteran Member
    1,103
    14
    Feb 6, 2000
    Montgomery IL
    My understanding is that the dual diaphram booster applies more presure at a given vacuum than a single booster so you will save room in the engine compartment and should get more assist. I have read that they operate at a lower vacuum as well but that may be just a function of providing greater assist at a vacuum threshold (low) where the single booster assist is so low, it is ineffective. I picked up a dual booster off of Rock Auto and C3 Vette 15/16" bore master awhile but have yet to test any of it. The factory 80-81 dual boosters are difficult to find anymore.
  6. AlbertaZ28
    299
    9
    Aug 17, 2010
    The DSE Master/Booster looks like a nice option but pricey. I paid $20 CDN so like $12 US for the this Master and Booster so I would like to make it work. From what I have read the dual diaphragm is the way to go with Disc/Disc brakes. I guess I will make the effort to change it out. Thanks for the replies.
  7. Zulu28
    Zulu28 Veteran Member
    299
    26
    Dec 19, 2013
    Vancouver, BC
    I'll be using 1980 T/a 4WD Booster and master with 5th Gen Bembo's all around
  8. AlbertaZ28
    299
    9
    Aug 17, 2010
    I think that is probably the easiest option if I can find one. They seem to be out of stock everywhere.
  9. Zulu28
    299
    26
    Dec 19, 2013
    Vancouver, BC
    Yes, the booster took nearly 4 months from Summit, price wise it was worth the wait and you know it's a bolt in, the Master shouldn't be a problem.
    AlbertaZ28 likes this.
  10. SS Performance
    SS Performance Veteran Member
    255
    40
    Nov 17, 2016
    Cape May Couny NJ
    I got mine from Camaro Central.
