Master Cylinder and Booster Advice
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by AlbertaZ28, May 7, 2020.
  1. AlbertaZ28
    AlbertaZ28 Veteran Member
    299
    9
    Aug 17, 2010
    Fort Mcmurray, Alberta
    Thanks for the replies. I've decided to replace the factory booster and try to use what I have. What I've done is cut the mounting bracket off the old booster and modified it to weld onto the 4th Gen booster. I also cut the push rod off the old booster, and the end of the new one. Then threaded both ends to 3/8-16 and used a coupling nut to join them. Just a bit of welding to do and it should be ready to install.
  2. AlbertaZ28
    299
    9
    Aug 17, 2010
    And here is the finished booster. Bolted in perfect.
  3. AlbertaZ28
    299
    9
    Aug 17, 2010
    Final update. The new 4th Gen master cylinder, Booster and 6th Gen Brakes work awesome. There is a nice firm pedal feel and the car stops better than ever.
  4. dcozzi
    dcozzi Veteran Member
    4,232
    1,202
    May 1, 2002
    Phoenix, AZ
    Does the end spin freely in the booster? Mine did in my manual cylinder so I welded the rod to the sleeve on the pedal side. I used a lock nut on the booster side of the sleeve and left some threads for adjustment. Not being a completely solid rod was a little unnerving for a crucial part. What did yours wind up looking like?
