master cylinder quesstion
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by wood0691, Apr 11, 2011.
  1. wood0691
    wood0691 Veteran Member
    175
    Apr 24, 2010
    Birmingham Alabama
    is this what my master cylinder is suppose to look like on my 79 Z ?
    i think its been changed.
  2. Twisted_Metal
    30,052
    2,778
    That looks like the 81 style.... Not original to your 79.
    Somebody missed one of the holes on the bracket when it was replaced too.
  3. wood0691
    175
    Apr 24, 2010
    Birmingham Alabama
    they missed all the holes, its just hanging by the pressure of the lines being so stiff. what should i do? replace with the correct one or try and fix what ive got as far as mounting?
  4. Twisted_Metal
    30,052
    2,778
    You should be able to remove the two nuts holding the master to the booster, hang the bracket where it belongs and re-install the nuts.
    If you have any question about the function of this one.... Get a new one from NAPA for $30, bench bleed it, swap it over and bleed your lines.
  5. Dogwater
    Dogwater Veteran Member
    926
    Dec 23, 2010
    SanAntonio Tx
    Don't put a cast iron master cyl. back on it, if you have to take the lid off more than once it going to leak.Try to leave that one on their,I just put one of those on my 78.
  6. 79T/Aman
    2,628
    248
    Oct 7, 2004
    Dickson TN.
    Say what!? maybe because you have a 33 year old seal or a China made chrome lid on the master, but lets face it GM and others have use them on millionS of cars for decadeS
  7. wood0691
    175
    Apr 24, 2010
    Birmingham Alabama
    im gonna have to change it to one of those millions that GM used. before i took the motor out the brakes were really grabbie, liked to lock up on the left side. im putting all new pads and shoes on it so why not change it back to what its suppose to be so i'll know its right.
    GEEEEEZ I hope it dont leak after i take the lid off a couple of times :eek:
  8. K5JMP
    10,216
    11
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    it could be a flexible line issue, stopped up hardline, caliper, prop valve or even just a warped rotor.
    these are all areas to investigate...
  9. wood0691
    175
    Apr 24, 2010
    Birmingham Alabama
    yeah, i was just gonna start with the master and the pads,shoes first then go from there. i hope not to have to further than that, but time will tell.
  10. Twisted_Metal
    30,052
    2,778
    Save yourself the cost of extra brake fluid and replace the rubber lines while you have the system apart.
    You will have to rebleed the whole thing after you replace the master so you might as well replace the rubber lines and bleed it once.
    The stock rubber lines aren't very expensive. (Two front and one rear will be about $50)
    The Russell kit (all three hoses, stainless braided steel) is $70 at AutoZone.
    http://www.autozone.com/autozone/pa...ouh?counter=0&itemIdentifier=127341_517559_0_
