Metal Instrument Bezel Source
Discussion in '1970 - 1973 Specific' started by Bernie Chaback, Aug 2, 2020.
  1. Bernie Chaback
    Bernie Chaback Member
    30
    Mar 13, 2020
    Rochester, NY
    Hello friends - so I've been thinking of replacing my instrument bezel and moving the gauges from the rear housing which has been modified already from stock - my speedo is original but remaining gauges were replaced long ago with Stewart Warner Stage III but I'd like to purchase something like a black annodized aluminum bezel similar in look to the Autometer #2132. Also since I'd be using the OE Speedo, I'd need a cover/lens to go over that to finish off the panel. Any suggestions would be appreciated.
  2. 70Znut
    70Znut Veteran Member Lifetime Gold Member
    230
    171
    Feb 5, 2016
    Sarasota,FL
    Bernie Chaback likes this.
  3. Bernie Chaback
    30
    Mar 13, 2020
    Rochester, NY
    Thank you for the reply regarding Keith - as I said, my speedo is OE so I'd need a trim ring/lens to cover if I placed in the Keith panel - any suggestions for a source? Thank you again for your reply - much appreciated and nice instrumentation. Mine has a long way to go.
