Mini starter upgrade
Discussion in 'High Tech Retrofits' started by frank5s, Dec 14, 2017.
  1. frank5s
    frank5s Veteran Member
    238
    20
    Sep 6, 2008
    Naperville Il
    If you are looking for a starter for your 2nd gen, l have recently replaced my heavy weight
    starter with a mini starter off of a 1999 Chevy Truck. Look for any chevy or gmc with a v8 with the vortex heads from 1996 up. Make sure to grab the starter bolts as they are shorter.
    The starters with the case bolts on the outside are slighter stronger.
    Nothing like a day at the junkyard, $16 bucks and a can of spray paint looks like new and works great. Don't let the teeth count stop you , the original has 9 and the mini has 11 but they do interchange.
    Frank
  2. McCune
    McCune Veteran Member
    1,211
    262
    Aug 22, 2015
    st.george utah
  3. BonzoHansen
    20,173
    1,470
    Jun 1, 2005
    Scott from Hamilton, NJ
    ^^That's probably the one I used. lock use a 98 k2500 454 for a lookup
  4. Zspoiler
    Zspoiler Veteran Member
    3,687
    336
    May 6, 2012
    Federal Way, Washington
    I just use a Tilton style starter in both my cars, With a Moroso heat shield,
  5. frank5s
    238
    20
    Sep 6, 2008
    Naperville Il
    I saw that starter on ebay but you will still need the knurled bolt which are shorter.
  6. Blown Camaro
    Blown Camaro American by birth, drag racer by choice
    1,199
    140
    Dec 13, 2009
    Deltona, FL
    I went to the Vortec starter thanks to a guy at O'Reillys WITH the new bolts and man, what a difference! I run a blower with locked timing and I don't care how hot the motor is it spins right over EVERYTIME. Don't even need to use the start retard in my timing box. Gained a lot of header clearance AND the wires have more airspace around them too. No heat shield needed! A+++. I think I spent about $40 on everything new (dealer discount).
  7. McCune
    1,211
    262
    Aug 22, 2015
    st.george utah
  8. badazz81z28
    18,636
    947
    Alabama
    Wow, I would have thought the heavy stock starters were gone 20 years ago. I remember reading about mini starters on these cars in 2001 when I joined.
    The stock ones sure are boat anchors.
  9. CorkyE
    10,855
    659
  10. McCune
    1,211
    262
    Aug 22, 2015
    st.george utah
    It will work.
    Blown Camaro likes this.
