Moog 5610 springs?
Fbird
6,450
atlanta, ga
#$%^%$....too LOW....was just un top of the tires!...only about 1/4 travel to contact. so went with 5660 moogs. straight in...gave me about 1/2" - 5/8" lift....works for first run. Will probably put a 1/4" spacer on TOP of spring...but we shall see.
Fbird
6,450
atlanta, ga
yes after tearing it apart I see the "tangs" up on the frame and only about 3/4" tall....so yeah can't put much up there. Alot depends on HOW the spacer is made!!! Soe are actually make convex so they actually would be able to locate the spring as well as raise it...but that's an entire another thread ;)
Fbird
6,450
atlanta, ga
went with the rubber spacers 3/8 " under the bottom as that is only a 1 hr job! Worked out well pics coming!
Fbird
6,450
atlanta, ga
finished stance!
full
Fbird
6,450
atlanta, ga
^^^^ well not really the "finished stance" as I am lowering the rear end and pie-cutting the slapper bars to pick them up some...almost there!
